We live on an estate which was built 3 years ago and on which every house (58) has had Parex rendering applied.
Some house have suffered issues with the rendering and now we are having issues too.
I won't comment on the problems others are having, or why we think they have occurred, but would ask for some thoughts from experienced individuals regarding our problems which are:
- render having come away on the corner of one wall by the corner bead
- the beading around one door being loose to the point of it being possible to move the bead along the whole of one side, and cracks being visible on the other
- large indentations (pitting the size of at least a 50 coin) appearing in various places
- render material still 'brushing' off the wall in various places.
The NHBC have inspected the property and agreed that the rendering needs attention (it is in a worse state after 3 years than I'd expect on a rendered property after 10 years - said the inspector) and are waiting for Parex to advise them how to proceed in rectifying the problems.
The developer has already undertaken remedial work on 2 properties under their 2 year warranty. One they removed all the rendering and re-rendered. The other they patched the problem areas and then applied a 'silicone' coating to all the walls.
Both of these remedial treatments raise concerns with me, but until Parex do their report for the NHBC we don't know what they will recommend.
The material used is Parex Monorex GM One Coat, and my question for the Parex experienced pros among you is - why could the developer not have simply done the patch repairs then to maintain uniformity of colour meshed and recoated the property on the walls where the repairs were done. The developer has said that this is not possible once the render has cured, and yet in the Parex material spec it mentions applying the material in 2 coats if a thickness of over 20mm in required.
Any thoughts appreciated
