S a plastering Private Member Jan 29, 2014 #1 What size do you generally go for I mean the notch depth of the tillers trowel when meshing thanks
Plasterers1StopShop Well-Known Member Jan 29, 2014 #2 12mm will give you a 6mm base and a 10mm notch will give you a 5mm base. All dependant on the system spec I'm using The Plasterers Forum Mobile App
S a plastering Private Member Jan 29, 2014 #3 The one I'm starting 120m wetherby an using 6mm beads first coat meshed then left to dry with the mesh in I'm going to use 10mm tilers trowel
Rigsby TPF Special Forces Feb 1, 2014 #4 Usually a 12mm but carry a 10mm around as well. Find notches level with beads then bed mesh in lightly, spat flat leaving about 2mm the grease over.
