Need to raise floor 40mm
popupstands
Hi I have laid 100mm insulation and around 60mm Screed but I need to raise it by another 40mm, do I need to seal screed? what is the cheapest and most sensible way to add 40mm
can I add another screed ?
would it be better to lay concrete with 10mm ballast for strength
Thanks in advance
flynnyman
Just wet it or even a cement slurry, I'm not sure what the minimum is for a screed on a solid floor but i think you will be safe :)
Jgreenplastering
Has it got to be spot on 40mm?
Could you not use another 25mm insulation then 18mm ply to create a floating floor?
If you want it solid then it's needs another coat of screed with fibres in and a good wet down/sbr between the coats To make sure they bond.
How did you manage to get 40mm short in the first place?
Ajax123
you can lay sand cement screed unbonded down to a minimum of 50mm or you can use an anhydrite screed down to 30mm minimum so 40mm is not really appropriate for sand cement unless you mechanically prepare the screed underneath. It is easily doable with anhydrite screed by simply laying a polythene membrane over the existing and pouring the anhydrite on top of it to the depth you need.
flynnyman
Is the 50mm not minimum for a floating floor?
malc
TPF Special Forces
cement slurry ! has been a no no for 20 years, slurry dries quicker then the screed leaving the screed hallow.
malc
TPF Special Forces
lay a coat of sbr on the base, while the sbr is still wet apply the screed with sbr in the screed mix. you have then built up a key, screed the floor.
popupstands
I have a guy who will screed floor this saturday, I am having screed delivered ready mixed with fibres would it be worth asking if I could add some SBR to mix ? or would this be a problem
