Oh theres a reason there is mould ,maybe the windows are single glazed, you may need to knock a vent out in that room to prvent the build up of condensation,if its a bathroom open the window after a shower.
That kit seems a bit dear,bleach or domestos dosent kill the fungus you should use a dedicated mould cleaner Home base used to do one or any product with benzalkonium chloride in it.
i had a problem with mould in a place i rented but before i could get hold of any remover i opted to get a colour match from B&Q (as i couldnt find the right coloured wallpaper) and painted over it, it covered beautifully! but then i found this... everbuild moss remover http://www.everbuild.co.uk/images/pdf/technical/404-Moss---Mould-Remover.doc
Bleach or a fungicidal wash. let that dry then paint it with a anti fungicidal paint that contains Carbendazine.This helps to stop the mould comeing back.
This stuff helps it FOR SURE !!!!! But it is not a cure.Just an aid to prevent it comeing back as quickly.
You get the paint from any Leyland / Johnstones centre
