level1plasterer
Hi guys just wanted to ask you a question about rendering, my old render was all the way to the ground! so I have cut it above the damp proof course,
and now I just want confirmation of the following
1. that i should render below dpc first, 3:1 scratch coat, then finishing coat 4:1 and then I leave a gap the size of the bellcast bead.
2. I then place a PVC bellcast bead above the dpc and then render the gap between the existing render and the bead is this correct? and do I put the PVC bead on with screws and plugs into the block
3. Do I need to make sure all the old render is chipped of with an sds hammer so it's all the way back to the block or can I have it up and down like it is as long as the render bead is flat and secure. Thanks for your help in advance guys
here are some photos guys, the plan is to use the sds hammer to clear the block so it is flat, so the scratch and final coat, bond well.
hope these help
hope these help
