monocouche
stevo81
Alright lads, I was just wondering what you lads do when using monocouche. Lets say your doing an elevation and the area applied first is ready for I section and scratch pad but lower down/further along the elevation feels a bit softer like it needs a bit longer. Would you wait until the last section applied is ready for finishing and I section and scratch the entire elevation or as the first section is ready, finish that then wait untill the rest is ready. Weve had some problems with colour deviations and could do with a little advice on the best method of avoiding this problem. Any advice would be much appreciated.
if youre waiting a long time between lifts open the bottom up first lightly then start at the top
once the top is ready then start because by time you get to the bottom that a be ready as well , or you can do as i showed spunky what to do and that is open the bottom up a bit with the I section but be carefull not to rip the surface
