Looking looking for a rough Guide ,not used it as yet I can now set the machine up no problem and strip it down for cleaning,the chap I bought it off said the setting is around 400 but I think that maybe way too muchMonos vary
You need Ryan and Andy on
Have you not used the M200 yet?
A bit sooner might have been helpful.Prime it at 300 just through the pink, then run through the pipe at 300. Generally around 200 is good depends what gear your using aswell though
300 ?Prime it at 300 just through the pink, then run through the pipe at 300. Generally around 200 is good depends what gear your using aswell though
