Monoblanco tips.
Jgreenplastering
Spraying this next week with ritmo.
Got about 150m2 over new block work.
Used blanc du litterol last year and can't recall any issues but that was hand applied.
Any tips on it?
Also is it quicker or slower set than normal Monorex?
Cheers
It's a swine when trying to whack 15mm on at once. Takes an age to be able to get on it and it still tears and slides all over the place.
Loads better over at 10mm over a base coat or if you have to a tight first pass that's pulled in quite a bit before topping.
Thanks mate, we always 2 pass with the Ritmo on new block tbh. Always usually a tight first one then top heavy.
Would love to base it first but time and money prevents.
Might look at that for future though if it works out to be a pain!
is it the old bl10 0r monoblanc both are still sold and supplied ? ones whiter than the other. there worlds apart, the old gear tears like a tart pain to rule, slumps etc.
the new stuff is a lot better but we find it still slumps a bit, so we spray a decent area before going over with a h bar, to let it pick it up a bit. the old gear sets quick new gear a bit slower a tad quicker than standard monorex. weve just done a site with 3 houses about 700 metres so weve got the art of it down to a tee with the ritmo.
Def monoblanco. Not used this before. Only had one blanc du litterol last year so not seen or felt the difference between use.
Hopefully this will be quite nice to get on with the ritmo then![emoji106][emoji106]
Mono blonco is terry ball.
Soon as you run a serrated edge through it it goes to piss. Prob spray 30 metres and fall back and rule off still wet and runs touch it with a spat it slumps. Helped a lad with a k4.. almost sprayed 40 metres still had to wait to spat it. Ritmo half the pace of a k4 so prob
Be on it quick.
Weber chaulk same colour Better kit
