User________removed
Does anybody know what additional additives go into factory batched renders like your OCR, to enable it to be used as a one coat application ?
The reason i ask is im wondering if its posible to modify normal sand cement & lime ? to use as a one coat system for maybe smaller jobs like pillars reveals etc !!
Maybe SBR ! not overly clued up on this kit, have used it over the years as a slurry for bonding and had great results. Also tried it in the scratch many years ago which was disastarous, ending up with a fairly weak scratch that sucked the death out of the top coat.
So would it be posible to modify Sand cement and lime with SBR in order to create a modifyed render that could be used as a one coat application, or a 2 coat application with better properties ? ie less shrinkage..
