Mesh beads
spunky
Is there a method to thin coat beads one end has 100mm the other has 20 is the longer mesh then the 20 mm over that, how do you get on with the corners I'm cutting mine like normal beads but the ends fray
where the mesh hangs down over the plastic bead juast cut them sections out spunk so the plastic meets neatly but mesh still hangs down either side also you will find that a good way of telling if the bead is straight is when there is no folds or creases in the mesh
