m tec 200 spray problem
Leno
hi guys and gals
I have been spraying weber with the m Tec 200 all been fine come to it today set up as normal good consistency through test pipe then when got material pipe on comes out really runny with little pressure on gauge tried the water down right to 140lm and still like piss any ideas before I phone p1 tomorrow cheers leno
hi guys and gals
Will be down to bridging or a build up in the chamber.
What speed and water were you running at?
Best to give us a call when having the issue and we will do our best to help you there and then
Putting on by hand today will set it up later in week and give Andy a bell (weber water at 220 and been spraying fine then had this problem tried water lower and higher even cleaned delivery pipe out and tried again )
I use the Weber most days mate now , I was wondering have you used a different material through the machine between sprays , Weber is always ok mate only time I’ve had issue is blocked air in the cap but my machine is ritmo m so maybe different, coming out like piss is normally a sign my rotar stator is duff
