Lowest tempreture to use STO
plastererEd
Fellors I have an outside extention to render, its wood on external, so gonna use some mesh, Plastic mesh, pin that up and render it.
My main question is, obviously if its too cold the gear will go off extremely quickly, but what would you say is the lowest temp I can work with this stuff outside before I get probs.
Ta :RpS_scared:
The manufacturers say 5c and rising. I work at min 3c so long as an overnight frost is not forecast or I can cover the work up and rely on some heat loss from the building.
