Liquid screed set up costs
McPlaster
Need a lot of gear don't you! Laser, tripods, dappling bars, flowring tester, 35mm hoses. Dear old game.
owls
it sure is, i reckon i have about 25 grand of kit.i have 50mm hoses for sand and cement aswell, there 600 quid for a 15metre run
owls
takes aggreagate up to around 9mm
just fire it into the hoper via the vibro plate.
McPlaster
Owls do you mean you are pumping semi dry traditional screed through a rotor and stator Utiform V2, If so is it moidfied with SBR or something?
owls
So would that machine pump and spray on normal site mixed S&C for internal floating work?
yes, if you load up the mixer at what ever ratio you want then fire it into the hoper.
the mixer takes 7 bags of mono at a time, so it can deal with sand cement volumes as well.
