lime render 3 coat outside how mutch is it per meter london area can any one tell me
is it flat lime work or london stucco where you have to form ashlar joints? some of london is conservation area and has to be done with mixes similar to original have a look here below
Exterior Stucco
dont even think about lime render until about april or may
each coat also take 10 or more days to carbonate before next coat can be applied so for 3 coats averaging 20 mm for scratch and float coat 5mm for finish coat total 25 days if not more if weather cool
also consider if it need protecting with mortar fleece and in hot or windy weather each coat will need misting so as not to carbonate too soon
how many m2 is there to do? as the more there is you could reduce your rates
hello and thanks for ur help there is only 150 m2 and its called k39 so he wants a price sort of ackward work so i think ill do it on day rate if price is not enough ...
K39 never heard of it... sort of awkward... hahahha post the K39 specification on here... do it on day rate... whatever the guy says -4c could be good start to both your induction... happy times
Your best bet is to pm a guy called spark2010 on the forum mate. He's into Venetian plastering and lime rendering but he's not on that often
This is cementicious not proper lime
Baumit Universal Render K 39
Product Datasheet
1. Product
Factory prepared dry powder mix in accordance with EN 998-1, general purpose, lime based render for manual and machine application
2. Suitable Uses
Baumit Universal Render K 39 is a lime based traditional render that can be used as basecoat and finishing coat, for all external and wet room areas, from the cellar to the roof. Can be applied onto most types of masonry, rough cast, concrete etc. Can be coated with lime based products such as Baumit Coloured Render Topcoat KRP, Baumit Decorative Roughcast Finish SEP, Baumit Equalisation Paint, silicate render finishes etc, all conventional paints and wall tiles.
3. Composition
Sand, high calcium lime and white cement and other additives to improve workability and adhesion.
4. Performance
For external use. Meets the physical and biological demands of the built environment. Suitable for application in designated wet rooms and other exposed areas. One material, from the basement to the roof. Flexible finishing options.
