i havent used lime before but am about to embark on re-plastering my house and im looking for good information / advice on how to go about this - anyone know of any good books, websites etc?
i did a search on here and theres quite a few posts featuring lime: do any of these give a good overview (i know this is a lazy question but theres stacks to wade through)? in particular im looking for info on mixing and types of lime / their uses. Render Systems has some good info here: http://www.limerenders.com/
the house is end of 1800s stone built (granite) with lime mortar and lime plaster. this has been added to: theres now an external skin of sand and cement render which arguably makes any internal lime plastering pointless but i figure there has to be some value in making any parts that need to breathe more breathable than they currently are.
theres a variety of plasters on the internal walls:
- entirely lime plastered and in good nick
- entirely lime plastered but with paint on top (i guess this traps any moisture and makes the lime 'useless')
- damp / blown lime plaster patches that i've removed leaving a big space that needs patching
- complete walls where the lime plaster as been removed
- lime plastered walls over-skimmed with gypsum
the obsessive / compulsive in me wants to remove everything but that would be a big job and very messy not to mention probably needless i.e. the lime walls with gypsum are fine (dry and not blown) so even though they arguably should go theyre doing the job so can stay. long-term id like to remove the sand and cement render but this is another big job and would be expensive as i couldnt undertake on my own.
this is what id like to do with each of the wall finishes i mention:
- entirely lime plastered and in good nick: OVER-SKIM USING LIME FINISHING PLASTER
- entirely lime plastered but with paint on top (i guess this traps any moisture and makes the lime 'useless'): KEY / SCOUR THE PLASTER AND OVER-SKIM WITH LIME FINISH PLASTER
- damp / blown lime plaster patches that i've removed leaving a big space that needs patching: FLOAT THE PATCH USING LIME AND FINISH ENTIRE WALL WITH NEW LIME FINISH
- complete walls where the lime plaster as been removed: REPLASTER IN LIME
- lime plastered walls over-skimmed with gypsum: RE-SKIM IN GYPSUM
does that lot make sense or do i need to go away and do a lot of reading / research? or do i need to recognise that the sand and cement render changes everything and that i should simply re-plaster using sand and cement (maybe with a bit of lime thrown in to give some breathability) and be done with it?
thanks
thanks
