JULIA Bentham
Recently applied KRend TC15 applied to house. Beading isn’t level and solution recommended is to re-bead and then go over with TC15. Is this likely to work? Any help
Would really need to see pics to advise on how to go about sorting it outSorry don't have pictures. About a brick out of level but more concerned as to coats of render. Beads are Krend bellcast as horizontal joint out. Thanks for help
It's hard to tell without a pic but if beads are out by that much there has not been a lot of thought gone into the job to be that far outThank you. Does this mean base coat area where re-beading only please?
If you take them on your phone then you can click upload picture just below and select them off your phone. ..... this is the extent of my help, I don’t do render!Thanks - trying to work out how to pictures! Yes can see not a lot of thought.
