k rendering
hi mate ,this is in the wrong section , but you might be safer here :RpS_thumbup: and no it dont need a base coat on new blockwork , depends on the type of block but mostly no .
As Church said, straight on 7n block in two passes. Weaker block should have a base with mesh and the Krend gang will recommend this.
Even with 7 newton ,still stress patch around openings and weep holes , or the lot to save worrying
