K rend upvc beads querry and goin round air bricks / vents
jack88
Got a K rend Job. Theres a section with air vents in the brickwork (pics attached). Just wondered what the options are for this. Thinking of going round it with stop beads to box it in.
Also attached pics of shallow wall returns and window revels which again would like to see what other options there are for finishing these other than using a stop bead up to the edge. Planning to use upvc beads with the k rend - as the stop beads are flat on 1 side and designed to recieve render up to the other side only, bit concerned with how to go about finishing the shallow reveal side of the bead. Can you go over the top?? :glare:
many thanks in advance!!
what you could do is cut down an ange bead and render into window,are you using the relevent base coat for the painted bricks
hi krend will only guarantee it if you use beads at every edge. yes i would bead round the vents, good luck by the way, krends good gear.
They advise eml and hp12 you can use the primer I'd you want it's just to control the suction
