Jub Basic
Rigsby
TPF Special Forces
Thanks dansouthcoast. Got a job to do next week of London facing brick. Got to apply Jub primer (vezercryl?) then 10mm Jub Basic render.
Is there anything I need to know like setting times, methods of rubbing up, advantages and disadvantages etc?
I am am hoping to spray it.
Dansouthcoast84
Not really mate. Basic is good gear. I hand apply. So i put 8mm coat. Rule and mesh. Cover the mesh.let it pick up. Pull a tight one over then sponge when its turning
Rigsby
TPF Special Forces
I dont know ocr prices. I pay 695 plus vat for basic. That goes 1.75m at 10mm
Direct in Bradford is charging £8.50 a bag. So it sound like a bit like W OCR? Spray 2/3, mesh then top third, serrated edge, spat, sponge.
Thanks for your advice.
Rigsby
TPF Special Forces
This customer wants a manufacturers warranty so using Weber is a no go! Jub accredited so Jub materials throughout for their warranty.
plasterjfe
OCR should never be more than 6.50. Thats dear considering you need to compete with site mix prices. Its great gear to use for straight render so is krend UF base.
Never knew JUB did a masonry base to be fair for thick rendering.
Dansouthcoast84
Agree a little steep. But for guarentees what can you do. Im not for one mixing and matching. I think its costly risk really.
Jub basic is for masonary only. They say not to use it even if youve hacked off. It trowels in better than jlm in my opinion. Dont tear
warriorupnorth
No, K rend in NI is as far as I have been.
Could try try buying off Jub direct next time. Jub quoted £25 for Vezercryl but direct charges £40.
John if you get stuck give me a shout , I could possibly get you what you need if you can pick up from Donny
we have a couple of really cool knauf days being announce d on monday :) and then there are a few others I am working on....
warriorupnorth
@Mapei do one to Italy @coriolenus
Sent from my HTC Sensation XL with Beats Audio X315e using The Plasterers Forum mobile app
