IT'S HERE!
They have been products in recent years launch, then fail. That tape really don't know, but I can staple quicker than that, and then less hassle removing staples If out of line. Uni finish I liked, had 1 fail with it, compensated. I see bq launch quick dry bonding, I think it will fail. Too expensive, also I can set bonding in any time I want. Bq no tape filler tried, it failed as many said on this forum. I'm hearing it is to be discontinued. Point to this post is manufacturers don't ask us guys what we would like. I have also had easifill blow off painted surfaces. Only use toupret now expensive.confidence in some of these products are low even if you follow spec, which I read and follow.
Which site are you on?
I don’t work on site anymore, to much health and safety plus s**t little cards you need which mean f**k all, I let my card run out which I got on grandfather rights it cost sixty quid for a silly health and safety course, a day off for the course and letters from firms that had used my exceptional skills, it didn't matter that I had plastered the stairwell in the controll tower at the Channel Tunnel for the dubious pleasure of which I had to go on a two day health and safety course. That’s enough griping for today
iwas told I could get a card years ago under the grandfather rights told em to stuff it its all all a load of b*ll***s the old 714 system worked ok and was free
To right, the 714 worked just fine, to get a 714 I had to provide my C&G papers and at least 3 years work history which I could prove through my apprenticeship.
I like bonding 60. We all know how to flash set normal bonding but that’s only good/safe for patching imo. Know where you are with 60 and can cover artex lids with it then skim straight away etc.
I prefer mrs jones artex ceilings. All I need is my handsome young buck card
I flash set it on artex ceilings lurpak
Rapid set cement or dirty water? Or something else?
I find dirty water flash it in 5 mins
Hydrated lime, a scraper full in say 7.5ltrs before adding bonding can set it in 20mins or so the more the quicker, adjust depending on bucket size and how quick you can get it on.
Heard this before but never tried, will give it a blast cheers
any body remember the general strike in the 70s when national front boys where throwing half bricks at u if worked on site
I'm like yourself a artex specialist. Lol. It takes a while to get used to, but perserver and you can bang thick patterns bonded quickly. You will never need bonding 60. 90% of artex ceilings I use bonding first rather than pissing about with finish plaster that loads do.
Haha . My preferred method is bit of bonding n skim to cover it. Let it go in then fresh mix skim very wet n put 2 really tight coats on one after the other. Pulls in quick too n cheaper than using pure bonding.
I do sometimes use bonding only to cover it all depends . Deffo gonna try lime tho
handful of cement dose the same
People lose their s**t if there's a bus/train strike f**k knows how they would survive constant power cuts tv going off air at random amd the three day week. An enduring image fom that time was workers huddled round brazier's.
People lose their s**t if there's a bus/train strike f**k knows who they would survive constant power cuts tv going off air at random amd the three day week. An enduring image fom that time was workers huddled round brazier's.
the strike I mean was building trade thing it was bad around Manchester Liverpool areas
put in a search for building trade strike in the seventys u will get it all on there I can tell u it was scary we even got threatened with arrest if we went to work as the unions said it was an unofficial strike and to carry on
Could'nt find what you meant, did find the general strike in 26. Cheers
