Insulated board ??
Chap got me round to quote this morning to dot n dab 2 walls in his spare bedroom and skim - very straightforward stuff but he asked that because the walls were single skin outside walls is there anyway I could use insulated board or insulate the wall before skimming
I've never used insulated board - is this the best course of action or would battening out the wall with some celotex between the uprights be better ?
Its a very small room and he is very keen to minimise any loss of width to his room
Or is there another way I haven't even thought of - any advice much appreciated, cheers guys
we have used insulated boards for dabbing b4. not the ones with kingspan on the back they had foam on the back with like a paper covering it. wus the spec on the whole site so im asuming it works
I hae just done very similar ... all i did was to put 25mm celotex sheets on the wall then battened over the top using 2 x 1 and 100mm plugs and screws then boarded as usual.
The insualted board is expensive and a t**t to use
Rich
go on to british gypsum website,plasterboards and gyproc thermal performance boards,it's all there,i use a lot of the thermaline plus,around £20 per sheet,depending on type.
just dab thermal bonded boards on the walls mate, then a few of the fisher type board fixings to keep em there in case of fire
I did half a house like this last year, just dabbed polystyrene backed boards on its a piece of doddle.
For some reason the middle of 2 of the boards came away (im presuming my ex-labourer did his usual half arsed job on the pva)
Anyway, I drilled two half inch holes in the board and fired a load of foam in and it worked a treat.
And sacked my labourer too.
Well thats not stricktly true he sacked himself by being a useless bastage.
Im with Rich here batten out @450 centres with 38mm wide wood ,then use 25mm jabelite or celotex then board with 9mm plasteboard and skim out.
I wouldnt want no comebacks.Dont take a lot longer or cost much more than dabbing.
I put the celotex on the walls and hold it in place with a bit of silicone or whatever then batten over the top, this gives you a 25mm void between the insulation and the board
