How to fill this in?
Karl t
Hi all,
After a accident in the kitchen I'm now needing to fill this in. (Picture attached)
Because of the push fit there ain't enough room to get a new bit of board in there as this hole is on the other side of the fuse box and It looks like they have put a piece of chipboard to separate the two so there not enough space in there.
Any advice on how to fill this would be great as I can't be doing with the nagging from the Mrs anymore.
Thanks In advance.
  • How to fill this in?
Put bonding on it then put scrim over the bonding and let the bonding set. Then use joint filler 2 or more coats then sand it when dry.
