Hi all,
I'm about to plaster/repair a significant portion of a bedroom wall around the door space and at a later date part of the adjacent wall (once it’s been checked out by a builder/surveyor) as its quite bowed up to about 3cm out of plumb in the middle. Once the door wall is finished, I will install a new door frame (already cut to size and rebated) and a new solid core door.
I had already noticed that the plaster around parts of the door was blown as there were a few cracks and also a lot of movement if you applied slight pressure to the wall.
I also noticed for the first time that the wall was not straight along the horizontal so much so that a long piece of wood placed horizontally on the wall would rock back and forth. The wall was also quite out of plumb around the door area (much more so than the rest of the wall).
I worked out the point where the wall went off at a tangent and also where it began to go out of plumb and cut the plaster back past these point so that I would have a good run up to create a straighter wall.
This following image shows the task at hand:
The wall depth back to the brick is: 2.6cm on the left side and around 2cm on the right side.
I built a frame around the door opening for the plaster to run up to and cut the wood accordingly so it is 2.6cm deep on the left and around 2cm on the right. (frame will be covered by architrave once walls plastered)
A spirit level shows that the finish coat should meet the edge of this frame fairly accurately. (I hope! :RpS_laugh
When I stripped the plaster back, the places where it had blown, were where the wooden studs are.
Do I need to cover the wooden studs with strips of plasterboard or would EML (expanded metal lath) be better?
I spoke to British gypsum and they said Victorian homes were decorated with lime based plasters.
Here is a close-up of the exposed plaster as it is all the way back to the brick:
Is this lime or gypsum plaster? The top painted layer was done about 14 years ago so is probably gypsum?
Before I heard about EML, I was planning to cover the wooden parts with strips of plasterboard and then building up with 2 keyed layers of bonding or hardwall and finishing off with 2 skim coats of multi finish.
Or should I just cover the entire area (brick and wood) with EML and then 2 keyed layers of bonding or hardwall and finishing off with 2 skim coats of multi finish.
Or does this look like lime plaster and another product is needed?
This is my first stint at plastering and I'm sure with the right advise, I'll do a fairly decent job.
I have a lot more pics if needed
Thanks for your time and advise
