We normally go by 10m2 per bag so if ceilings 17m2 and its artex, i like it thick on first coat to get plenty on to cover the artex, i'd do about 2 bags (20m2) to cover artex then half again for second coat (1 bag). This makes sure all the artex is covered and you've nothing to worry about. No matter how heavy the artex is i've never bonded it out first, thats 3 coats and whats the point when you can do it in 2! Artex is one thing it won't go far on board its a lot diffrent.
Best advise always take more multi than you will need, that way you won't run out and always mix slighty more than you need as its easier to clean out bucket once you're finished rather than trying to knock up more mix when you're already chasing your tail!
plaster shrinks when it dries mate and you won't be going over a coat of multi when it's rock hard because it wont adhere, if you bear in mind a coat of plaster does go on 2-3 mm you could get this deviance even on a slight stipple
if you use a tight coat of bonding ...which you should especially if the artex is a heavy bark effect etc at least the plaster has cured you'll get a normal suction from the backing coat, if you lay a second coat onto a green backing coat you'll get indifferent suction because it's not a flat background and it'll pull in together leaving hollows
very good point is this...
maybe im just lazy but the one thing i hate having to do is bonding followed by skim, too many people will just follow the 2 coats of skim method, me included.. i only bond out something if i absolutely have to... like when theres big hollows etc... 99 percent of the time with artex its a thick suction coat, pull in and top it and to be honest, the amount of houses ive been involved/priced for and done the whole job as complete redevelopments, the only problems i get are plaster delamination due to dodgy chalky paint under another 2 coats of whatever... or too little suction and it ripples like a fat bird... or even two coat pva dont kill it.. when its painted its never bang on but completely saleable and the walls are always a thousand times better for two coats of multi... end of the day its an overskim... if its perfection they want with very little chance of future problems its drop it and reboard...
incidentaly, this weeks job... reskim whole house for a property developer....
we'll finish skimming tomorrow, the kitchen was done 1st hit monday, still aint dry, and they got a painter in 12 hours after us...
paints lookin ok so far on what has been reboarded, even some that hasnt hes been cracking on with...
we've had silk paint over distemper, the skims soaked into the cracks in the silk, loosened the distemper, had 1/3rd of a ceiling down today... and the f'cker always waits till your on your second trowel after toppin it...
they get what they wanna pay for, what they though they could get away with turns out they couldnt...
gypbond was king this week....
converted my mate too... old school plasterer...
ah well, all plasterers go to heaven, property developers end up in hell tied to stakes in mounds of burning 50 pound notes  ;D
plastering can be so fickle sometimes...
lets all offer up prayers to the gods of suction and adhesion and get em to leave us alone for a bit... Â :
