high impact render
ian
ive got to render the inside of dog kennels where working dogs are kept ... the owner has had experience with render before , of the dogs scratching at it back to the brick . can i use some sort of additive or is there a product available as an alternative to s & c .. is limlite an option ... many thanks
I once did an internal render and used sulphate resisting cement mixed with sand and SBR, jesus man when it set and dried it was bomb proof
i think if you one coat it with a 3:1 mix with a sharpish sand and plenty waterproofer youd have to be a pretty nasty dog to make any sort of impression... they'd soon give up when their paws started to bleed..
a 6:1 mix with no waterproofer just aint that hard...
isnt 'potassium sulphate' a bomb making ingredient? :D
I'd go with a drop of sbr too, also, if you wet it the follow day with a light spray it might set a bit harder as well (this is a screeders trick, i'm only assuming it works the same with render)
aye, they reckon concrete sets like well, er really hard concrete underwater...
30 people found stuck to a wall outside heathrow airport...
police believe irish muslims set off the worlds first 'no more nails' bomb :D
thanks lads thats spot on ... even a sabretoothed greywip ;D wouldnt damage those mixes .. should be the answer to his problems
