Help identifiying render
GARZX9R
Hi all, i'm half way through building my garage/bedroom extension, the top half of the existing house is rendered, it isn't sand/cement render, monocouche and doesn't look like a tyrolene, it seems to be built up of one thick coat of a coloured system but the final finish looks like a very very fine grit that looks as if it was sprayed on, I would like to match the new to the existing to save a bit of work, but I was thinking if I find it hard in matching i'll just monocouche the new and then have no choice to monocouche the existing so it all matches,
cheers
stu
cheers
stu
Posting a picture might get you a more accurate opinion
you don't think someone would have put the dreaded woodchip wallpaper up on the outside do you,once painted that stuff stays up forever
I managed to get answer to my question tonight, the girlfriends uncle is a plasterer so I sent him a picture on his mobile, he said it has been a coloured base coat render then a sprayed on thin top coat acrylic, he said It defo hasn't been troweled off. But trowelling off will get me the closest finish with not having a sprayer
