Floor screed m2
heafy
What's an average labour only price for floor screeding. I've done a couple of jobs in the past but I've only been on a day rate. I have a floor to put in which is going to be 65mm minimum up to around 85-90mm thick. Any ideas so I can give a price next week. Thanks
As said thousands of times on this forum work out how long it will take you then add your materials with 20 percent added on it all depends on the area you are doing for instance if say its 15 per m2 and you have 4 m2 to cover you aint going to charge 60 quid are you I just wouldn't be worth it so just figure out how much u want to make
