Falling Damp ???
D Deleted member 23452 Guest Oct 13, 2015 #3 You'd need some good drainage underneath it. If the substrate was on clay for example the potential for frost damage would be huge. So depending on the sub-soil type that could be a very expensive option. Good stuff where it can be used though.
stuart23 Private Member Oct 13, 2015 #4 At end of vid it says cold will damage it and can only be used in hot countries so that rules us out
Danny - Oct 13, 2015 #5 imago said: You'd need some good drainage underneath it. If the substrate was on clay for example the potential for frost damage would be huge. So depending on the sub-soil type that could be a very expensive option. Good stuff where it can be used though. Click to expand... FReeze thaw weathering would be brutal I should think....
