xyzplasterer
How do you form external corners without using beads?
Some corners are 6 metres high from ground level, I'm using Eco Cork render (2 coats)
I've done bellcasts before using timer and wetting it down is it a similar method for corners...
The elevations are large so I wont be doing both sides of the corner the same day.
