exact angle corner trowel
brimplas1
bought one of these off ebay last week and couldnt believe when it came that marshalltown had put their name on it ! it was so flimsy and cheap, on the box it states that it will work on angles between 90-150 degrees!!!!! like my *ss it does it will go nowhere near 90 degrees! any one else out there bought one ?
there ok for vaulted ceilings if your on tight price and need to do the whole room in a set. no good for 90's. open it slightly wider than it needs to be an push it into the angle. like i say only use it when needs must.
Seen them but never really fancied it, it must have some uses as grump says. could use it as a bucket scoop I suppose:-0
Got one and also got a refina one the refina is loads better as made of stainless steel so no flex
Bought a plazzy one, marshalltown.
Absolute garbage. The little two inch refina ss one is my tool of choice now.
Prefer these corner trowels...........
