If you need it with sponge only I’ll go for rokamat or similar. The epg can get a bit heavy after while
Is that the cordless one at £1500If you need it with sponge only I’ll go for rokamat or similar. The epg can get a bit heavy after while
It is just for sponging really. Have you used the diamond float much with yours?If you need it with sponge only I’ll go for rokamat or similar. The epg can get a bit heavy after while
Days work that for youIs that the cordless one at £1500![]()
If only mate, I’d only work 1 day a week lolDays work that for you![]()
Ok ok , we bring it to one days work thenIf only mate, I’d only work 1 day a week lol
Scrape and sponge mostly. Diamond float is perfect for compression, but if timing is wrong it digs in.It is just for sponging really. Have you used the diamond float much with yours?
Too pricey for me that. I’d rather take the weight of the eibenstockOk ok , we bring it to one days work then
http://www.alphacut.co.uk/index.php?route=product/product&manufacturer_id=21&product_id=601
No mate , you’ll get the sponge only! How much is the disc btw?@vfr12 Yanno when you buy a sponge. Does it come with the plastic disc that holds the velcro part of the sponge? I’m looking at buying one but it’s only been used to scratch back mono. Doesn’t have any sponge kit with it. It’s not clear on websites what you get when you buy a sponge. A sponge on its own is useless because there would be nothing to stick it to.
Put up the links! There are different types of sponges mate, I think the disks are separate?The ones on eBay are about £40-50. But some are £20. I’m hoping the ones that are £20 are sponge only and the more expensive ones are the ones with the plastic attachment pad.
Damn! Can’t beleive there isn’t a backing plate for sale. Velcro parts wear outFirst one is just replacement plates for scratch
Second medium hard sponge
Third-soft sponge
Not got it yet. Been offered it for decent money from a fella local to me. He bought it with the scratch pads setup.Did you get powerfloat? You should have the disk ?
Just buy Velcro and cut It to size. One of my sponges was missing one and I had to improvise. Much better than the ones refina is using.Damn! Can’t beleive there isn’t a backing plate for sale. Velcro parts wear out
It would only be for s&c or ocr. Not into mono.For scratch pads I use normal replacements, cut in half.
Not sure yet. Will go and see him tomorrow.Do you have the diamond disc? You can adopt one if you have two? If it’s one- no point.
You mean c**t cunting? Well done mateI’m here, in the bath![]()
Go easy on the cunting. Make me feel a right c**t lolYou mean c**t cunting? Well done mate![]()
Have you seen the latest prices in the EPG gear? Come right down. Sponges £10!You mean c**t cunting? Well done mate![]()
That’s very good news indeed! Will have a look mate . CheersHave you seen the latest prices in the EPG gear? Come right down. Sponges £10!
Clean and unused so farHow is the Ritmo![]()
Treat it with acf 50 to get you through the winterClean and unused so far![]()
