robholliday85
Hi everyone Got cable end to render
the people im doing it for are a bit on the flash side and want to splash out on EML which is great because ive never actually used the stuff
can anyone correct me if this is wrong
1. remove existing render
2. sbr
3 fix eml with the screws and washers
4. scratch coat
5. rubbing up coat
was wondering if lime is still needed with the eml. also do i really need a scratch coat with eml and if i do why
is it ok to put a bit of sbr in with your mix or does this mess with the lime
and finally what mix ratio is best for scratch (if needed) and top coat with eml? im going onto those old imperial bricks
hope everyones ok and making proper money again
RH
2. sbr
4. scratch coat
5. rubbing up coat
RH
