Dri coat
Yakka13280
I've got a damp proof job coming up and have been recommended dri coat as an alternative to traditional sand and cement.It is about 30mm thick to bring out to the original a metre up.is it possible to do say 2 14mm coats on seperate days then skim?otherwise i will just sand and cement it.
Hi mate yes it's possible to build it out using fully keyed coats but at that sort of thickness the coverage would be less then 1m2 a bag so personally id forget about the dri coat.
Same day mate is no problem, it sets pretty quick on the walls. Personally at that thickness I’d use dri coat for the speed
