R rs004e7074 New Member Sep 8, 2011 #1 HI, anyone regulary using dri coat plaster,what procedure for using it ,salt neutraliser,etc before applying the plaster,not to sure?
S Scouse Member Sep 8, 2011 #2 Hack off back to brick, brush down wall (dust), drill - inject wall and apply Dri Coat, key, leave for 24 hr skim. It's got all the additives in it. Oh and mix outside if possible, horrible stuff to mix, but nice to use.
P Privatepyle11 New Member Mar 30, 2012 #4 Hi when skimming over dri-coat do you need to put pva on first or do you just wet the surface with water?
Rossi46 Private Member Apr 2, 2012 #5 Privatepyle11 said: Hi when skimming over dri-coat do you need to put pva on first or do you just wet the surface with water? Click to expand... Depends how long it's been left for. Generally skim the day after applying the dri coat. If it's been left for longer a bit of PVA won't do any harm.
