Dabbing PIR plasterboard.
Skimble
Got a job d&d PIR boards, new one for me so was hoping for some advice. Is it normal procedure and anything to watch out for?
and around window/door reveals is there anything to know as there will be some insulation on show, is this skimmable?
You need to put secondary fixings in them, on corners/reveals cut out the foam on the edge of one so the other slots in so there's no foam on show
We use to cut the thickness of the insulation off 1 board edge so it sat tight and once boarded looked like normal pboard
I do loads of dabbing with them they are obsessed with them on new builds and renovations up here. I have used the mitre and remove foam and butt joint method and if you have loads to do i think mitre is quicker cos it is only one cut.
Starting the dabbing tomo. How do you guys secure the top reveal while the addy goes off? I'm guessing screwing into the lintel is a bad idea!
