Barry Egan
Find the centre Point for the the circle run a gig stick for a perfect job,otherwise use a feather edge straight edge using the best tool in your kit, your eye .
Cheers Baz, get up to much else last night?Find the centre Point for the the circle run a gig stick for a perfect job,otherwise use a feather edge straight edge using the best tool in your kit, your eye .
Not a lot, don't get up to much these days.
Is that a clever word for wonky ceiling lines?I’ve got an ellipse shaped room to plaster.
Any tips?
Any tips?
Elipse shaped trowel.I’ve got an ellipse shaped room to plaster.
Any tips?
FornicatedIs that a clever word for wonky ceiling lines?
w**k*rbest tool is at the end of your arm its called a wrist
Depends on how big the room but you could try a tramel or work out where you're 3 centre's are, then go from there.I’ve got an ellipse shaped room to plaster.
Any tips?
