A while back I taking my chimney breast out and so now I need to put up a new length of coving.
My problem is the old coving is imperial so if I fix 127 mm it will not line up with the profiles
on existing coving . Am nearly thinking of running a peice in situ.
Ive done the same before. Was in the middle of nowhere and had to match a new piece of bg up to old gyproc. Like flynny says.make sure the bottom matches up and you can fiddle and fill the rest.
