I always used cove adhesive and have done it on the same day..Anyone tried coving on a wall skimmed earlier that day, got a job where I need to plaster wall in morning then cove in afternoon. Didn't know whether perhaps sticks like s**t would be better than cove adhesive for this situation? Any advice would be great
same as skirting first basicallywhy would you cove 1st that is mad i always cove after never had made a key and unless its cornice i always use artex and never had any probs..but everyone does it diffrent sure u make a mess of cove if cove is put up 1st?
its nicer if coved after skim in my opinion.. damp ingress would be minimal from a 2/3 mm of skim compared to the moisture in the cove adhesive, over thinking a simple job..
i remember that we had a letter from nhbc about 20 years ago asking everyone not to use artex to fix cove.I use artex to stick it up
i always use gyproc cove as the knauf cove goes a dark colour, which we dont like, when we sponge down to clean up.If you do it on the same day, the damp will transfer to the coving and there is a possibility that it will go yellow if painted white.
true..Bit of a different story on rendered & skimmed surfaces.
the knauf adhesive is very corse, not as good finish. we usually run a watered down coat of pva on ceiling and walls, as we find this makes cleaning down quickerWas using both BG and Knauf today, coves and adhesives. BG is far superior. Knauf is brittle, lots of air pockets and their addy is coarse as f@ck.
Artex is not designed to fix coving.
Nail gun?Fixing coving to pva :-0
oh deary deary me :-(
Nail gun?
Easifill 20 says on bag can be used for coving used it loads for when there's one length to put up as sets in 20 minutesLike whats been said cove first then skim but im not sure about eazyfill might as well use cove adhesive.
Why would you make a mess clean it down with a sponge and clean water ,if you have just one wall to do and one length of cove to fix , cove first as then you don't have to wait for wall to go hard before coving , as of you cove when plaster is soft you scratch the wall , so this way better job and job done quickerwhy would you cove 1st that is mad i always cove after never had made a key and unless its cornice i always use artex and never had any probs..but everyone does it diffrent sure u make a mess of cove if cove is put up 1st?
