beader
Only if you treat your transit van like s**t , but treat it with love and respect it will last for years .a bit like tools.A carbon is like a transit van brilliant to work with but rusts like fook
You can't stop a trannie rustingOnly if you treat your transit van like s**t , but treat it with love and respect it will last for years .a bit like tools.![]()
Early on another thread spats speedskim Carbon was mentioned etc just found searching this comment is this true for a lot of users on here??Much better for flat trowelling K as having more spring means you don't need to apply so much pressure. The patina is not a problem comes off first rub.
I have a carbon MT trowel for years , only used for trowelling skim . I haven't used oil in a long time , so long as you dry it well at the end of the day it won't rust . They get nice and sharp to easy trowelling but will get nicked very easy too
I've got a 13x5 Carbon, is a nice trowel. Would recommend.I just ordered a steel 13 by 5 MT but after reading this would anyone recommend carbon instead? Wanted a change from the permashpe and mine is turning into a banana as well but never had anything different any thoughts??
I just start skimming with them out of the box, some guys break them in on render first or use a whetstone I think.What's a steel one like for braking in manually? And what process best to use?
I wonder myself about these flexies , my old carbon trowel is pretty flexy at this stage . Ill report back after I try out a fewI have a MT 18 inch carbon, a great trowel. I have tried to upload the photo but it just says error occurede. I don't rate these fancy flexis and the likes. I just don't see the point myself but each to there own.
Hi what do you blacken the top of trowel with looks nice
WaterHi what do you blacken the top of trowel with looks nice
Exactly I always wd40 mine every eveningAfter using it, dry it, oil it.
