Bullnose corners
Jameswb
Hi all,
Customer wants walls skimmed but retain bullnose corners around reveals. What's the best way to skim these without cracking later on? I'm going to use a sponge and bag when trowelling. Should I be taping or double taping the corner or not needed?
Cheers
As above pal you can get a good finish with just your trowel if you put that extra bit off effort in but none the less a bag and a sponge is ok I use a strip of Visqueen if needed
