I have just had an extension built which i am plastering. i have 100mm cavities from my concrete blocks to my windows and wanted to know if i just dot and dab the board with nohing in the cavity or do i put noggins in for the board to rest on. Whats the best option
Also i have 2.4 x 1.2 boards for the vaulted ceiling. there is 2 of us putting up the boards but am having a massivie struggle. we have some scaffy boards and trellus but finding it very difficult to get the boards up. Can anyone share there methods. I really could do with some help
Why are you plasterboarding the vaulted ceiling I have always floated them. Are you cutting the paper on the back of the boards every 50-75mm and snapping the cuts to help the board bend?
Make sure you are at the right height before you start your head should only be a couple of inches from the joists, make up a dead man or use props there more of a technique to it than you think. What board are you using fire check ?
