Monkey Boy
Bonding is s**t
f**k**g blebs
I’m s**t
f**k**g timing s**t
f**k**g blebs
I’m s**t
f**k**g timing s**t
Clean you bucket out every mix .. end of ..Bonding is s**t
f**k**g blebs
I’m s**t
f**k**g timing s**t
It’s a feisty oneLittle tip with bonding if the job permits it skim bonding the next day, or wait for it to completely dry
Anything else??? LolFinish will bleb if the background is to wet, no suction or applied thickly
always was a problem with any carlite plaster but multi wrong stuff altogetherBonding is s**t
f**k**g blebs
I’m s**t
f**k**g timing s**t
Put a hand full of lime in the mix it sends the bonding off really fastBonding is s**t
f**k**g blebs
I’m s**t
f**k**g timing s**t
Are we talking “bonding 30” lolPut a hand full of lime in the mix it sends the bonding off really fast
When I put it onAnything else??? Lol
My dad use to do that circular motion, pressing hard with a float after a splash of waterTo get rid of blebs let the gear pull and near the end put your trowel flat on the wall and rub round in a circle over the blebs it gets them out then give it a cross job done
If the decorator pisses you off it puts a proper shine on the plasterMy dad use to do that circular motion, pressing hard with a float after a splash of water
Yep but better to have to sand a key than sand bubbles I guessIf the decorator pisses you off it puts a proper shine on the plaster
Or hack em off if too bad re apply any gear left over to fill the crater/patch and quickly knock up a third coat lolTo get rid of blebs let the gear pull and near the end put your trowel flat on the wall and rub round in a circle over the blebs it gets them out then give it a cross job done
Haha Sounds like a lot of work buddy wax on wax off technique for meOr hack em off if too bad re apply any gear left over to fill the crater/patch and quickly knock up a third coat lol
What I got told but never get em cause I.m bonding master @Retired SpreadTo get rid of blebs let the gear pull and near the end put your trowel flat on the wall and rub round in a circle over the blebs it gets them out then give it a cross job done
Don't know haven't skimmed anything for years it's beneath me now I'm a rock hard rendererDoes it work with a plazi?![]()
I just thought it was not a background too wet thing but that the water gets pulled away too fast or in a way the air can’t escape with it and it gets trappedDo you know, or can you find out from BG, what is actually happening, technically-speaking, that causes blebs?
Is it a problem with chemistry? By all means correct me if I'm wrong, but your above answer seems to point to moisture lingering too much in the skim, but that wouldn't explain why it invariably tends to happen when skimming over bonding. It seems the bonding itself is affecting the skim in some way.
Do bonding plaster additives like perlite or vermiculite make the surface of the dried bonding plaster have different suction in the tiny localised areas where the perlite or vermiculite particles are closest to the surface?
I tried to glean some insight with a few web searches, but about the only thing even slightly relevant didn't answer my question (well, not that my limited intellect could see), and it's 40 yrs old:
nvlpubs.nist.gov/nistpubs/Legacy/TN/nbstechnicalnote755.pdf
I'm not asking to be a nerd. I'm asking for a more thorough understanding, as blebs are bloody annoying, and it'd be nice to have a definitive answer from BG.
Cheers.
I’m not 100% sure that they have the data in a technical format but I will ask.Do you know, or can you find out from BG, what is actually happening, technically-speaking, that causes blebs?
Cheers.
If the plaster dries out to fast, high suction or heat, you get crazing and the plaster will be soft. The water is drawn from the material before it sets and stops the crystal growth in the Gypsum.I just thought it was not a background too wet thing but that the water gets pulled away too fast or in a way the air can’t escape with it and it gets trapped
I will ask the scientists but be warned, I might not be able to spell some of the words they use, never mind understand them.
Is that with the spelling or understanding, I need to cover all basesIf you get stuck mate I.m here
Both I’ve done a course
