Cheers for the helpChoose the insulation board for the u-value required and any fire regs that might be needed to meet. You have eps, pir, pur, mineral wool etc etc.
Good thin coat systems:
Weber
Parex
Dryvit
Ivas
Mapei
Enewall
Sto
Alumasc
Knauf marmorit
Sas prorend
Envirowall
Permarock
And more but can't go wrong with any of the above
A firm local in Fenton deals with styrobond for the adhesive/base coat but primer/finish is a bit on the high side k - rend seemed a good deal i take this popular with u lads on ere when using eps insulation ??
There rep got in touch yeh there place isn't far from me ,she recommended acrylic finish is there any pitfalls I should be aware of or is is straight forward enoughJust ring Envirowall get all from there it's cheap enough
Get some one on board to help you out mate I would.this will give you a good idea how to do your next oneSorry I mean is that the best finish too use because she mentioned the silicone finish aswell what's the difference ??
