Bell cast and corner beads
PotatoSack
Hi Guys,
I have rendered a few walls with S&C before with good results. For my next project, I will be using bell casts above DPC, but the problem is they protrude about 20/25mm from the wall, whereas the corner beads only protrude about 10mm.
Do the corner beads need to be protruding out as much as the bell casts ? If so, how can I achieve this? I could put them on top of the scratch coat, but the scratch coat is only 5mm thick.
Cut them a bit then gently bend out to meet the bell cast..........tadah.....
You are welcome.
No really, it's no trouble........I'd do the same for anyone....
No honestly, you owe me nothing.....
Look, buy me a pint the next time you see me.....
Cheers
