B bart New Member Jan 3, 2012 #1 i need a quick way to form raised quoins in sand&cement on a new build stop beads or battens
essexandy The Lake Governor Jan 3, 2012 #3 d*m**o said: Plastering Corner Stones - YouTube Click to expand... Is that you doing those quoins Dom?
Rigsby TPF Special Forces Jan 3, 2012 #6 It looked thick render on the vid. Risk of cracking? Maybe Weber OCR may be safer to use at that thickness.
S s.p.t plastering Active Member Jan 4, 2012 #7 I love that vid, really smart work...Would love to get some work like that!
plasterjfe Private Member Jan 4, 2012 #8 bart said: i need a quick way to form raised quoins in sand&cement on a new build stop beads or battens Click to expand... sounds like a compromise on doing it properly, I would suggest cut by hand. how quick do you mean tho
warriorupnorth Private Member Jan 4, 2012 #9 We did all the qouins on this job freehand, not as formal as the ones below/above, but still really effective (Owls asked me to put this one up) Last edited by a moderator: Mar 17, 2015
warriorupnorth Private Member Jan 6, 2012 #12 Really easy with mono without any battens or beads, not exactly quoins but you can see how easy they could be created
