Artex sealer
solutions
Looking for something with a bit more b*ll***s in it to even out suction other than pva. Does anyone use artex sealer? Is one or two coats needed and once applied will it still need to be pva'd
cheers
Hi there, You need to introduce yourself in the Hello section. You will get scant response otherwise. Just a brief hello, where you live, job title etc. Just forim etiquette :RpS_thumbup:
I use it thined 50/50 with water as a plaster primer ready to take emulsion. Works well and no crazing like you get with pva. I also have used it for years to seal artexed ceiling ready to plaster skim as I find it seals better than pva. And for sealing ready to artex a ceiling as like I said before it seals better than pva
