You can set them before or with the scratch coat mate!Depends if there a bellcast going on ,you would need to scratch first then put on bellcast ,then set beads. :-?
You ca use a bellcast bead across the wall horizontally to split it in two halves, get it strait though or it will look crap, You can divide a wall long ways vertically with an expansion bead, to separate it into sections
