dogsbreakfast
Howdy. Drywall contractor here with an airless texture sprayer. Wondering why no one seems to spray their hardwall this way since it gives a far cleaner fan than the mono pump + compressor videos I've seen, would lay on a hell of a lot more volume, and doesn't need a compressor.
Would the shear from a piston pump's action kick off setting quicker than a rotor stator? I've never put a setting compound through it so am curious.
Are plastering contractors favouring progressive cavity pumps because the one machine will move any material (like S&C) or is there something unholy going to happen if I put a gypsum/lime mix through a piston pump at 3000+ psi?
Cheers.
Cheers.
