Air blisters in k rend
Creedon93
Sponge finishing white k rend, floats up perfectly but noticed a few small air blister when sun shines on it, wall was scratch coated with sand and cement and top coat k rend, pulled serrated edge on it and straightened second coat with straight edge, what causes this?
John j
Mono Don
Air
bobski
Background, dampened?
Scratched properly?
Size of trowel, compression not pressed in hard enough, (sometimes using a big trowel)
Or was it sprayed on?
In our case scratch with a stiff brush and then a scratcher. Walls r wet according to weather and conditions, wen floating and esp sponging can see the air bubble in top coat which hasn't keyed to the scratch. 13 inch carbon hand applied. Little additives in mix, lime and small bit mortar mix in top coat gear does b raw enough. Fibres and mortar mix in scratch and cap full of sbr to 3 bags of cement in mixer for scratch.
CeeVee
Always used to get this when not spraying it on.
Guessed it was just a 'hand applying' thing.
Creedon93
It was scratched properly and the perfect thickness left for top coat, the rest of the house is perfect its just this one patch, it was hand applied, k rend I relatively new to us its mostly sand and cement we work with, how long should the k rend be left sit after pulling serrated edge on it?
bobski
Both cases,
Used to get that with sand that is not that great.
When we've had that when hand applying this final coat, is to mix creamy, press a very tight coat in - really press it into every void, and then to glide one straight over the top. (Straight after while still wet.)
Obviously depending on wall size and man power, will determine timings.
woodeneye
You didn't follow the system...
woodeneye
Laying on too quick and no agitation in your trowel action. All about the wiggle push the air out. Also happens when making your second pass too soon.
