Dirtybill
Done a small plaster repair job few weeks back about 1m2 in a living room, now the problem is that there is a dark line as though it hasnt dried properlyt between the finish on the patch i did marrying into the existing plaster which is old school plaster (lime maybe not sure) this line seems to be persisting even after the painter using a stain block and two coats its still evident.
Anyone got any suggestions as to what the problem might be?
Forgot to mention the area i plastered had been damaged before and when they renovated and i think they used plaster board then a backin plaster (browining) on top then multi, could the gyproc behind have any sort of effect?
